: 01 paź 2019, 12:34
autor: protulus
Tuesday,01,October,2019,12:21:14
039 906 024 D ,,DIGIFANT 1.75 1714,
,Group A:,'000,,,,,,,,,,Group B:, Not Running,,,,Group C:, Not Running
,TIME,,,,,,,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP,,,,,,,,,,,STAMP,,,,,STAMP,,,,
,0.00,060,148,003,026,175,000,000,023,004,206,,,,,,,,,,
,0.87,060,148,003,026,168,000,017,025,004,205,,,,,,,,,,
,1.73,060,148,003,075,160,000,040,050,009,206,,,,,,,,,,
,2.57,060,148,003,077,131,000,000,051,006,176,,,,,,,,,,
,3.41,060,148,003,075,126,000,000,051,005,176,,,,,,,,,,
,4.25,060,148,003,075,132,000,000,072,005,166,,,,,,,,,,
,5.10,060,148,003,075,126,000,000,076,004,156,,,,,,,,,,
,5.94,060,148,003,079,129,000,000,080,004,149,,,,,,,,,,
,6.84,061,148,003,096,133,000,000,091,004,135,,,,,,,,,,
,7.71,061,148,003,083,143,000,000,023,003,145,,,,,,,,,,
,8.61,060,148,003,028,138,023,000,023,003,189,,,,,,,,,,
,9.49,061,148,003,046,156,000,001,023,004,202,,,,,,,,,,
,10.38,060,148,004,036,169,000,026,023,004,204,,,,,,,,,,
,11.27,060,148,004,033,174,000,000,023,004,206,,,,,,,,,,
,12.14,060,148,004,076,179,000,000,056,006,186,,,,,,,,,,
,13.02,060,148,004,076,135,000,000,061,004,163,,,,,,,,,,
,13.90,061,148,004,075,129,000,000,068,004,158,,,,,,,,,,
,14.77,060,148,004,075,133,000,000,072,003,157,,,,,,,,,,
,15.59,061,148,004,089,143,000,000,080,004,149,,,,,,,,,,
,16.45,061,148,004,091,151,000,000,082,003,145,,,,,,,,,,
,17.33,061,148,004,092,162,000,025,083,003,143,,,,,,,,,,
,18.18,061,148,004,093,173,000,000,023,003,149,,,,,,,,,,
,19.05,061,148,004,056,183,000,000,023,003,176,,,,,,,,,,
,19.93,061,148,004,023,186,007,000,023,009,229,,,,,,,,,,
,20.82,061,148,004,069,174,000,003,023,005,184,,,,,,,,,,
,21.70,061,148,004,064,134,000,000,023,005,194,,,,,,,,,,
,22.56,061,148,004,059,127,000,000,023,004,194,,,,,,,,,,
,23.44,061,148,004,041,126,000,000,023,004,204,,,,,,,,,,
,24.34,061,148,004,040,131,000,000,023,004,206,,,,,,,,,,
,25.22,061,148,004,040,139,000,000,023,004,204,,,,,,,,,,
,26.09,061,148,004,077,149,000,000,051,004,176,,,,,,,,,,
,26.98,061,148,004,077,130,000,000,051,004,166,,,,,,,,,,
,27.85,061,148,004,077,135,000,000,054,003,165,,,,,,,,,,
,28.76,061,148,004,075,144,000,000,069,004,168,,,,,,,,,,
,29.65,061,148,004,092,162,000,018,079,004,161,,,,,,,,,,
,30.51,061,148,004,098,176,000,000,083,004,149,,,,,,,,,,
,31.42,061,148,004,099,185,000,000,084,004,140,,,,,,,,,,
,32.29,061,148,004,093,191,000,000,023,003,148,,,,,,,,,,
,33.19,061,148,004,042,196,023,000,023,003,191,,,,,,,,,,
,34.07,061,148,004,037,203,000,000,023,004,201,,,,,,,,,,
,34.93,061,148,004,037,205,000,000,023,004,205,,,,,,,,,,
,35.81,061,148,004,036,207,000,000,023,004,205,,,,,,,,,,
,36.69,061,148,004,036,209,000,000,023,004,204,,,,,,,,,,
,37.57,061,148,004,036,211,000,000,023,004,205,,,,,,,,,,
,38.48,061,148,004,058,213,000,000,036,007,203,,,,,,,,,,
,39.34,061,148,004,076,193,000,000,045,005,173,,,,,,,,,,
,40.25,061,148,004,074,142,000,000,054,004,170,,,,,,,,,,
,41.13,061,148,004,075,129,000,000,067,004,161,,,,,,,,,,
,41.98,061,148,004,091,137,000,000,080,004,151,,,,,,,,,,
,42.84,061,148,004,093,142,000,000,082,003,142,,,,,,,,,,
,43.73,061,148,004,083,151,000,000,023,004,142,,,,,,,,,,
,44.63,061,148,004,071,168,000,041,023,003,172,,,,,,,,,,
,45.49,061,148,004,026,187,008,000,023,005,222,,,,,,,,,,
,46.39,061,148,004,075,199,000,000,023,005,184,,,,,,,,,,
,47.28,061,148,004,073,152,000,000,023,005,191,,,,,,,,,,
,48.15,061,148,004,072,129,000,000,023,006,193,,,,,,,,,,
,49.00,061,148,004,073,126,000,000,034,006,191,,,,,,,,,,
,49.89,061,148,004,060,125,000,000,023,005,183,,,,,,,,,,
,50.77,061,148,004,054,125,000,000,023,003,184,,,,,,,,,,
,51.64,061,148,004,039,126,000,000,023,004,196,,,,,,,,,,
,52.51,061,148,003,036,130,000,000,023,004,205,,,,,,,,,,
,53.38,061,148,004,033,137,000,000,023,004,206,,,,,,,,,,
,54.26,061,148,004,034,147,000,000,023,004,208,,,,,,,,,,
,55.14,061,148,004,035,163,000,010,023,004,206,,,,,,,,,,
,56.02,061,148,004,035,177,000,000,023,004,207,,,,,,,,,,
,56.90,061,148,004,072,187,000,000,038,005,186,,,,,,,,,,
,57.77,061,148,004,075,137,000,000,050,004,171,,,,,,,,,,
,58.63,061,148,004,075,129,000,000,067,004,163,,,,,,,,,,
,59.52,061,148,004,086,140,000,000,077,004,160,,,,,,,,,,
,60.37,061,148,004,099,158,000,006,089,004,144,,,,,,,,,,
,61.28,061,148,004,102,170,000,070,023,003,142,,,,,,,,,,
,62.16,061,148,004,044,184,000,000,023,000,183,,,,,,,,,,
,63.03,061,148,004,030,195,002,000,023,004,209,,,,,,,,,,
,63.91,061,148,004,034,203,000,000,023,004,206,,,,,,,,,,
,64.78,061,148,004,034,207,000,000,023,004,206,,,,,,,,,,
Oto i logi silnika.
Zrobiłem też też na w razie w skrzyni ale tylko w pozycji P.
Tuesday,01,October,2019,12:18:48
097 927 731 DK ,,AG4 Getriebe 097 1484,
,Group A:,'001,,,,Group B:,'002,,,,Group C:,'003
,, ,Voltage,Load,Bin. Bits,,Current,Current,Voltage,Voltage,,Speed,RPM, ,Load
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP,, V,%,,STAMP, A, A, V, V,STAMP, km/h, /min,,%
,0.40, P,0.25,50.0,00100111,1.72,0.004,0.000,13.81,2.46,4.62,0.0,1800, 0,50.0
,15.67, P,0.25,50.0,00100111,16.99,0.004,0.000,13.88,2.46,19.87,0.0,1740, 0,50.0
,21.16, P,0.68,50.0,00100111,22.44,0.004,0.000,13.88,2.46,25.31,0.0,960, 0,50.0
Jak coś to robiłem je na benzynie.
Nie wiem czy wspominałem, ale sprawdzałem multimetrem na tym drugim kablu do wtyczki jak zmienia się napięcie podczas otwierania przepustnicy i nie było żadnych przerw, napięcie płynnie się zwiększało. Jednak przez to czyjeś druciarstwo tam nie gwarantuje mi to nigdy, że podczas jazdy też tak jest. Samochód podskoczy na górce, a to wszystko jest tam zlutowane na słowo honoru i problemy. Zaraz po zapłonie samochód jedzie w miarę, potem się gubi.
