[B4 1z] throttle response
: 14 kwie 2013, 23:30
autor: RS_TDI
Sometimes it works fine, but sometimes when i press gas pedal it doesn't react immediately from the beginning. What should it be?
: 15 kwie 2013, 09:38
autor: gibaj
potentiometer gas? or pump controller :roll: and what about the VAG? What engine accessories? bosh or PIERBURG?
: 15 kwie 2013, 10:11
autor: RS_TDI
Pierburg, and I tried to put a new one but no difference. Potentiometer of gas pedal should be ok as a tested it with VAG com....I was also thinking about pump controller but I asked if there is some advice to try more something...
