|Audi 80 B4 1.8T| zmiana licznika na licznik RS6 C5
: 20 cze 2022, 13:48
autor: tomasz84
Witajcie.
Pacjent audi 80 B4 avant 95 quattro. było 2.6 obecnie jest 1.8T słupek AEB na osprzęcie AWT.
Krótko i na temat - plan jest by uruchomić w nim liczydło z RS6 C5 |zegary przeprogramowane na 1.8 z korektą poziomu paliwa|
Pinout liczydła rsa mam...
Blue 2000,2001 +
1 - Terminal 15
2 - Brake pad wear
3 - Speedometer output 1
4 - Not assigned
5 - Tank sensor
6 - Tank warning OBD 2
7 - Terminal 31 (sensor Ground (GND))
8 - Coolant temperature
9 - Terminal 31 (load Ground (GND))
10 - Oil pressure 2 (high)
11 - RPM signal
12 - A/C shut-off
13 - E-Gas/glow plug control
14 - Level control
15 - Terminal 58d
16 - Trailer turn signal
17 - High beam
18 - Left turn signal
19 - Not assigned
20 - Terminal 58s
21 - Driver door contact
22 - Lack of coolant
23 - Terminal 30
24 - Terminal 31 (load Ground (GND))
25 - Consumption signal
26 - Right parking lamp
27 - Left parking lamp
28 - Tachometer input
29 - Brake
30 - S-contact
31 - Speedometer output 2
32 - ESP/ASR
Green 2000+
1 - Not assigned
2 - Transponder
3 - Not assigned
4 - Not assigned
5 - W-wire
6 - Not assigned
7 - Right turn signal
8 - External buzzer
9 - External gong
10 - Airbag
11 - Stand-still time output
12 - Terminal 61
13 - Parking brake/BRAKE
14 - CHECK
15 - Oil level/oil temperature
16 - Not assigned
17 - Transponder 2
18 - CAN low speed (powertrain) (high +)
19 - CAN low speed (powertrain) (low -)
20 - CAN low speed (powertrain) (screen)
21 - ABS
22 - CAN low speed (comfort) (high +)
23 - CAN low speed (comfort) (low -)
24 - CAN low speed (comfort) (screen)
25 - Hood
26 - Fuel filler cap
27 - Belt buckle
28 - K-wire
29 - Outside temperature -input
30 - Terminal 58d (ext. Dimmer potentiometer)
31 - Selector range display
32 - Automatic vertical headlamp aim control system
Gray 2000+ clusters
1 - Switch for menu control (Menu)
2 - Switch for menu control (out A)
3 - Switch for menu control (out B)
4 - Switch for menu control (Enter)
5 - CAN high speed Display (high +)
6 - CAN high speed Display (low -)
7 - CAN high speed Display (screen)
8 - not used
9 - not used
10 - not used
11 - Enable
12 - Clock-
13 - Data-
14 - Brake light
15 - Wash water level
16 - Tail light/Low beam (Light control)
17 - On board computer left
18 - On board computer right
19 - On board computer reset
20 - Remote control input for auxiliary heater
21 - Summer /Winter Switch
22 - Auxiliary heater on
23 - Push button branch 1 Navigation
24 - Push button branch 2 Navigation
25 - Push button branch Telematik
26 - not used
27 - not used
28 - not used
29 - not used
30 - not used
31 - not used
32 - not used
Pinout liczydła 80 b4 bez AC/BC bo u mnie był "golas" w 2.6 - nie wiem czy dobry znalazłem.
NIEBIESKA 26PIN:
1.---
2.---
3.---
4.---
5.---
6.---
7.---
8.---
9.---
10. ABS (żółto-czerwony)
11.---
12.---
13. Prędkościomierz (żółto-brązowy)
14.---
15. Poziom paliwa (fioletowo-czarny)
16. +12V po zapłonie (czarno-niebieski)
17. Prawy kierunkowskaz (czarno-zielony)
18. System kontroli (biało-niebieski)
19.---
20. Wejście sygnału prędkości (brązowo-czerwony)
21. Poziom paliwa (brązowy)
22.---
23. Światła drogowe (niebiesko-biały)
24.---
25. Airbag (biało-żółty)
26. +12V po zapłonie (czarno-niebieski)
ŻÓŁTA 26PIN:
1. ??? HOT W/PARK OR HEADLIGHTS ON ??? (szaro zielony)
2. Temperatura płynu chłodniczego (niebiesko-brązowy)
3. +12V po zapłonie
4.---
5. Podświetlenie zegarów (szaro-niebieski)
6.---
7.---
8. Masa (brązowy)
9. Lewy kierunkowskaz (czarno-biały)
10. Poziom płynu chłodniczego (niebiesko-żółty)
11. ???Brak płynu hamulcowego??? (siwo-żółty)
12.---
13. Ładowanie (niebieski)
14.---
15.---
16.---
17.---
18.---
19. +12V stały (czerwono-niebieski)
20.---
21.---
22. Obrotomierz (zielono-niebieski)
23. ???Masa??? (brązowo-czarny)
24. ???Masa???
25. Hamulec ręczny (brązowo-biały)
26. Świece żarowe (brązowo-zielony)
Na pewno bedę musiał podłączyć linie CAN z ECU. I czeka mnie też rozszyfrowanie dołożonej wiązki z wtyczkami pod licznik z B5 full fis analog zegar. Ciężko na nim cokolwiek sprawdzić bo fis jest w słabym stanie. Wiem że wtyczki są inne więc i tak czeka mnie przeróbka juz pod 3x32.
