[a80 b3 6a] 2 powracajace bledy lambda i mieszanka
misiek_gda
Post autor: misiek_gda » 22 kwie 2011, 16:26
VCDS Version: Release 10.6.0
Data version: 20100630
Friday,22,April,2011,12:25:22:46862
Chassis Type: 8C - Audi 80/S2 B4
Scan: 01 02 03 08 15 25
Address 01: Engine Labels: None
Part No: 893 907 404 P
Component: MOTOR PMC 00
VCID: 2C5C06EEB051217C
3 Faults Found
00525 - Oxygen (Lambda) Sensor (G39)
03-10 - No Signal - Intermittent
00537 - Lambda (Oxygen Sensor) Regulation
08-10 - Control Limit Surpassed - Intermittent
00587 - Mixture Control Adjustment Limit
09-10 - Adaptation Limit Surpassed - Intermittent
Readiness: N/A
End ---------------------------------------------------------------------
po kasacji zostalo
Friday,22,April,2011,12:39:58:46862
Control Module Part Number: 893 907 404 P
Component and/or Version: MOTOR PMC 00
Software Coding:
Work Shop Code:
2 Faults Found
09-00 - Adaptation Limit Surpassed
Readiness: N/A
zastanawia mnie ten blad
czy bedzie on zwiazany z lambda czy z jakas regulacja sie klania?
po wymianie sondy powracaja 2 bledy w kolejnosci mixture puzniej sonda
