Witajcie.
Pacjent audi 80 B4 avant 95 quattro. było 2.6 obecnie jest 1.8T słupek AEB na osprzęcie AWT.
Krótko i na temat - plan jest by uruchomić w nim liczydło z RS6 C5 |zegary przeprogramowane na 1.8 z korektą poziomu paliwa|
Pinout liczydła rsa mam...
Blue 2000,2001 +
1 - Terminal 15
2 - Brake pad wear
3 - Speedometer output 1
4 - Not assigned
5 - Tank sensor
6 - Tank warning OBD 2
7 - Terminal 31 (sensor Ground (GND))
8 - Coolant temperature
9 - Terminal 31 (load Ground (GND))
10 - Oil pressure 2 (high)
11 - RPM signal
12 - A/C shut-off
13 - E-Gas/glow plug control
14 - Level control
15 - Terminal 58d
16 - Trailer turn signal
17 - High beam
18 - Left turn signal
19 - Not assigned
20 - Terminal 58s
21 - Driver door contact
22 - Lack of coolant
23 - Terminal 30
24 - Terminal 31 (load Ground (GND))
25 - Consumption signal
26 - Right parking lamp
27 - Left parking lamp
28 - Tachometer input
29 - Brake
30 - S-contact
31 - Speedometer output 2
32 - ESP/ASR
Green 2000+
1 - Not assigned
2 - Transponder
3 - Not assigned
4 - Not assigned
5 - W-wire
6 - Not assigned
7 - Right turn signal
8 - External buzzer
9 - External gong
10 - Airbag
11 - Stand-still time output
12 - Terminal 61
13 - Parking brake/BRAKE
14 - CHECK
15 - Oil level/oil temperature
16 - Not assigned
17 - Transponder 2
18 - CAN low speed (powertrain) (high +)
19 - CAN low speed (powertrain) (low -)
20 - CAN low speed (powertrain) (screen)
21 - ABS
22 - CAN low speed (comfort) (high +)
23 - CAN low speed (comfort) (low -)
24 - CAN low speed (comfort) (screen)
25 - Hood
26 - Fuel filler cap
27 - Belt buckle
28 - K-wire
29 - Outside temperature -input
30 - Terminal 58d (ext. Dimmer potentiometer)
31 - Selector range display
32 - Automatic vertical headlamp aim control system
Gray 2000+ clusters
1 - Switch for menu control (Menu)
2 - Switch for menu control (out A)
3 - Switch for menu control (out B)
4 - Switch for menu control (Enter)
5 - CAN high speed Display (high +)
6 - CAN high speed Display (low -)
7 - CAN high speed Display (screen)
8 - not used
9 - not used
10 - not used
11 - Enable
12 - Clock-
13 - Data-
14 - Brake light
15 - Wash water level
16 - Tail light/Low beam (Light control)
17 - On board computer left
18 - On board computer right
19 - On board computer reset
20 - Remote control input for auxiliary heater
21 - Summer /Winter Switch
22 - Auxiliary heater on
23 - Push button branch 1 Navigation
24 - Push button branch 2 Navigation
25 - Push button branch Telematik
26 - not used
27 - not used
28 - not used
29 - not used
30 - not used
31 - not used
32 - not used
Pinout liczydła 80 b4 bez AC/BC bo u mnie był "golas" w 2.6 - nie wiem czy dobry znalazłem.
NIEBIESKA 26PIN:
1.---
2.---
3.---
4.---
5.---
6.---
7.---
8.---
9.---
10. ABS (żółto-czerwony)
11.---
12.---
13. Prędkościomierz (żółto-brązowy)
14.---
15. Poziom paliwa (fioletowo-czarny)
16. +12V po zapłonie (czarno-niebieski)
17. Prawy kierunkowskaz (czarno-zielony)
18. System kontroli (biało-niebieski)
19.---
20. Wejście sygnału prędkości (brązowo-czerwony)
21. Poziom paliwa (brązowy)
22.---
23. Światła drogowe (niebiesko-biały)
24.---
25. Airbag (biało-żółty)
26. +12V po zapłonie (czarno-niebieski)
ŻÓŁTA 26PIN:
1. ??? HOT W/PARK OR HEADLIGHTS ON ??? (szaro zielony)
2. Temperatura płynu chłodniczego (niebiesko-brązowy)
3. +12V po zapłonie
4.---
5. Podświetlenie zegarów (szaro-niebieski)
6.---
7.---
8. Masa (brązowy)
9. Lewy kierunkowskaz (czarno-biały)
10. Poziom płynu chłodniczego (niebiesko-żółty)
11. ???Brak płynu hamulcowego??? (siwo-żółty)
12.---
13. Ładowanie (niebieski)
14.---
15.---
16.---
17.---
18.---
19. +12V stały (czerwono-niebieski)
20.---
21.---
22. Obrotomierz (zielono-niebieski)
23. ???Masa??? (brązowo-czarny)
24. ???Masa???
25. Hamulec ręczny (brązowo-biały)
26. Świece żarowe (brązowo-zielony)
Na pewno bedę musiał podłączyć linie CAN z ECU. I czeka mnie też rozszyfrowanie dołożonej wiązki z wtyczkami pod licznik z B5 full fis analog zegar. Ciężko na nim cokolwiek sprawdzić bo fis jest w słabym stanie. Wiem że wtyczki są inne więc i tak czeka mnie przeróbka juz pod 3x32.
- Strona główna Audi 80/90 - Forum Techniczne Elektryka i elektromechanika Przełączniki zespolone, zegary, stacyjka.
|Audi 80 B4 1.8T| zmiana licznika na licznik RS6 C5
- tomasz84
- Imię: Tomasz
- Nadwozie: Avant quattro
- Silnik: 2.6 ABC
Post autor: tomasz84 » 20 cze 2022, 13:48
- Załączniki
- rs6.jpg (504.38 KiB) Przejrzano 81 razy
Przejdź do
- Audi 80/90 - Forum podstawowe
- ↳ Przedstaw się nam
- ↳ Regulamin Forum Audi 80 Klub Polska
- ↳ Dział Forum Audi 80
- ↳ Poszukiwany/Poszukiwana
- ↳ Polecam/Odradzam
- ↳ Polecam lub nie Klubowicza
- ↳ Polecam lub nie spoza forum
- ↳ Na każdy temat
- ↳ Spoty, zloty i grupy lokalne
- ↳ Klub Audi 80
- ↳ dolnośląskie
- ↳ Kujawsko-Pomorskie
- ↳ Lubuskie
- ↳ Małopolskie
- ↳ Lubelskie
- ↳ Mazowieckie
- ↳ Łódzkie
- ↳ Opolskie
- ↳ Podlaskie
- ↳ Śląskie
- ↳ Podkarpackie
- ↳ Pomorskie
- ↳ Świętokrzyskie
- ↳ Warmińsko-Mazurskie
- ↳ Wielkopolskie
- ↳ Zachodniopomorskie
- ↳ Spot'kania na wysokim szczeblu
- ↳ Gadżety
- ↳ Społeczność sympatyków. Stara nasza historia.
- Audi 80/90 - Forum Techniczne
- ↳ Silniki benzynowe i LPG.
- ↳ Silniki czterocylindrowe
- ↳ Silniki pięciocylindrowe.
- ↳ Silniki V6
- ↳ Zasilanie LPG
- ↳ Inne.
- ↳ Silniki wysokoprężne
- ↳ Silniki TD
- ↳ Silniki TDi
- ↳ Pompy wtryskowe i wtryskiwacze
- ↳ Turbiny i układ dolotowy
- ↳ Inne.
- ↳ Układ napędowy i skrzynie biegów.
- ↳ Przekładnie i skrzynie biegów
- ↳ Półosie i przeguby
- ↳ Inne.
- ↳ Zawieszenie
- ↳ Amortyzatory i sprężyny
- ↳ Koła i felgi
- ↳ Hamulce tarczowe, bębnowe.
- ↳ Zawieszenie tylne
- ↳ Maglownice, końcówki drążków, geometria.
- ↳ Wahacze, zwrotnice
- ↳ Inne.
- ↳ Elektryka i elektromechanika
- ↳ Lusterka, szyby, szyberdach.
- ↳ Centralny zamek, alarm, immobilajzer.
- ↳ Nawiew, klimatyzacja, ogrzewanie.
- ↳ Przełączniki zespolone, zegary, stacyjka.
- ↳ Oświetlenie wewnętrzne i zewnętrzne
- ↳ Komora silnika
- ↳ Systemy bezpieczeństwa Air bag i ABS
- ↳ Inne.
- ↳ Nadwozie i wnętrze
- ↳ Elementy karoserii
- ↳ Wnętrze i tapicerka
- ↳ Inne.
- ↳ Inne
- ↳ Kupujemy Audi 80/90, Coupe, Cabrio
- Firm / usług / reklamy
- ↳ Promocje, reklamy firm.
- Audi 80/90 Tuning, rezanie i stylizacja
- ↳ Warsztat czyli zrób to sam
- ↳ Rezanie
- ↳ Naprawy
- ↳ Inne.
- ↳ Tuning mechaniczny
- ↳ Tuning wizualny
- ↳ Car Audio, GPS, CB.
- ↳ Pielęgnacja i kosmetyka
- Audi 80/90 - Galerie własnych zdjęć, tematów, postów
- ↳ Audi 80/90 - B1 / B2.
- ↳ Audi 80/90 - B3.
- ↳ Audi 80/90 - B4.
- ↳ Audi Coupe / Cabrio.
- ↳ Inne Audi np: A3, A4, A6, TT itd.
- ↳ Inna marka np: Vw, Opel, Toyota, Skoda itd.
- ↳ Motocykle, skutery i quady.
- ↳ Archiwum starych zdjęć.
- Audi 80/90 - Filmy i unikalne zdjęcia
- ↳ Filmy i unikalne zdjęcia
- Audi 80/90 - Ogłoszenia
- ↳ Kupię
- ↳ Zamienię
- ↳ Usługi
- ↳ Sprzedam pojazd
- ↳ Sprzedam różności
- Audi 80/90 - Centrum
- ↳ Aktualności
- ↳ Ciekawostki i galerie
- ↳ Historia modeli
- ↳ Wyposażenie
- Usunięte, zbędne tematy
- ↳ Śmietnik
